2005 GEMS do not have a method to prevent cart operation with the parking brake engaged. By adding $25 worth of parts and a couple of hours work this problem is easily corrected.
PARTS
(2) Regular parking brake limit switches. Do NOT reuse original. 6 bucks each at Club Car Dealer.
(10’) 16 ga. wire
(6) Ty Wraps
(2) 1/4’ female spade connectors
(2) butt connectors
(2) 3mm X 1 1/4 " machine screws with nuts
(1) piece steel scrap for joiner
Solder
Normal hand tools plus Heavy duty soldering iron.
We are adding a limit switch to open the foot pedal signal to the controller until the parking break is released.
With this add If you don’t release the parking brake and press the pedal you will get a code 5 and the car will not move.
AKA Old Houseboater
