Working on a 2005 GEM that shudders and stalls intermittently under acceleration. Contacted an expert who suggested the park brake interlock switch was to blame. Vehicle literally would not move after being stopped midride to pick up children and had to be towed. Per his advice, cycled the park brake and it seemed to resolve the issue on 2 occasions.
My questions are:
1, Is this a common issue?
2, What could be possible causes of this symptom?
3, Is there a part I should be replacing commonly to blame for this??
The parking brake limit switch controls the safety functions related to movement of the cart when parked and the enabling of the cart when the brake is off.
It is more suspect when the cart wont move when the handle is down. Bangit down hard will sometimes allow the cart to move. Usually this can be cured with adjustment but at 14 bucks its a good candidate for replacement
Shudder is NOT usually caused by problems with this switch.
Brush sticking, brakes hanging , programming ,connections, and mechanical are more suspect.
[quote=OLD HOUSEBOATER;27972]The parking brake limit switch controls the safety functions related to movement of the cart when parked and the enabling of the cart when the brake is off.
Rodney[/quote]
Somebody posted that 2005 GEM e4s did NOT have a Park Brake InterLock Switch
