Legitimate dealers can ask to be let in for chance to test.
$150
Message me to qualify. May be some delays.
Target price is $350 retail.
Possible kits will be made available for diy, after successful testing.
Send me your unopened pedal. I will update it with add-on electronic sensor. Restores full torque. As mechanical brushes age torque request to controller diminishes. You can test pin #7. >3.1 volts required at wot. Holzer sensor is similar to the 2016 type Hall effect throttles that will not age out.
This does not effect your oem function. Switch back any time to compare. (Not guaranteed as brushes may be damaged during conversion)
Versatile Application:Designed for a range of models, making it a versatile choice.
Throttle Pedal Position Sensor|Throttle Pedal Sensor|OEM Compatibility:Precision-engineered to match many OEM specifications, ensuring a seamless fit and function.
High-Quality Sensor Type:Equipped with a Holzer sensor type, known for its reliability and durability. Also known as hall effect.
Wide Measuring Range:Offers a broad measuring range, catering to various throttle positions for precise control.
Extensive OE Reference List:Includes a comprehensive list of OE references for Polaris Gem and diesel rv models, ensuring compatibility.
Will an rv do? It turns out that 1,000s of rvs used the teleflex throttle that the 2005+ gems used. And being mechanical, all are failing.
A used one on Ebay asking $1100. No free shipping either. Lol
