FOR SALE
2002 e4
very nice and lots of upgrades
4700 miles
I’ve personally put around 2000 myself
Aways stored in heated garage
Custom blue paint and matching dash
Custom led taillights
14” SS wheels
Blue led under glow lights
3 yr old crown batteries
700$ wet sounds Bluetooth sound bar
New sunroof
All new suspension bushings installed last year
3 year old delta Q charger
Had the factory recall done with the power converter. all done
Set of factor hard doors
I’ve never used them. They are in no where near as nice shape as the car. I’ve never used them. Need good cleaning and I believe 2 handles in the windows are cracked off
No rips or tears in seats
Paint is almost perfect except the back piece is starting to crack again like all the older models do
I had it bondoed and painted 3 times. Still likes the crack but seems to be cracked to the max point. See pictures
I changed gear lube every year
Checked battery water regularly
Car needs nothing and runs perfect
Only issues with car are
Back fender is cracked a little bit
Rear trunk does not lock
The locked fell off inside. I have it. Just needs to be re glued on somehow
Only selling because this last year I haven’t used it nearly as much as prior years
$7900
Call or text
Dan
269-449-7998Uploading: C3036DBE-1563-4A76-9220-A07C9F621D46.jpeg… Uploading: 6065DF4F-E8C6-4CF6-B343-A8A7347C6F3E.jpeg… Uploading: AEC17DF2-F338-4BBF-B542-27A4BFE81C8E.jpeg… Uploading: 7D0F5B96-EDE6-457D-8AAE-09236AF3B278.jpeg… Uploading: 4DE2DFE8-12E7-4B1A-B487-39863887365B.jpeg…
