2001 turn signal issues
I am having trouble with right turn signal shutting down head lights, horn and both turn signals. Will reset itself after I cycle on and off and wait a minute or two. Had a bad bulb in rear right (blinker filament out) and replaced it. Everything worked including left blinker until I tried right. Same issue. Except bulb is still good right now. If I don’t touch right turn blinker, seems to be perfect lights in every respect. (Unfortunately right blinker is probably one of the most needed for safety issues!) Because of my disability my ability to do the work really impedes me from doing a lot, and I am on a tight budget. Anyone have a similar issue and is there an easy fix?
