I have cables for both T1 8 pin and T2 12 pin.
Where are you getting the software for the T1. Forktruck Electronics has been sold out for over 6 months. I wasn’t aware of of another vendor.
I can sell you an EZ Steer for your cart.
Rodney keep in mind if you sell him a ez steer it needs to be extended. You can see in the photo he posted that his steering shaft had been extended.
I caught that.
The 4" strap is the rear mount.
Other picture shows the top shock mount extended down 4".
Front mount is not shown.
Still running strong at 79% battery. 73.2 volts unloaded.
[quote=OLD HOUSEBOATER;26109]I have cables for both T1 8 pin and T2 12 pin.
Rodney[/quote]
I helped Forktruck with something once, so he seems real helpful to me.
He claims that my Sentry sw will work with T1.
Guess I won’t know until I try.
All I need is the dongle, which has been sold out.
That I can build myself. If sw works I would offer dongle and instructions.
I thought that I would need data file for the T1. He say’s no???
Rodney[/quote]
What is ez steer?
Does it reduce interference and friction, or does it increase mechanical advantage, as a gearbox or arm change?
My steering seems ok. Lots of under steer, but I like that for stable feel in corners.
Never looked it over. I have no idea what type of steering is used.
Ez steer is a reducer that makes your steering on the older cars 99-05 way way better
I have a 08 as well as a 02 and the steering on my 02 is much better then on my 08
2 to 1 gearbox built into column - reduces effort 50%. Popular with 1999-2004 owners wives.
[quote=OLD HOUSEBOATER;26054]It will go into turtle mode if battery pack gets to low. If your looking for setting #s for a T! email me. I have the hand held programmer. Do you have the 8pin cable adaptor?
I have my 99 programmed for 40MPH but have it crippled down to 35 to get reasonable range.
Rodney[/quote]
I hope an LX GE handset is what I need. Found one for $150.
I’d have that much in parts and effort, by the time I get my Sentry sw working.
May have to make a cable.
That’s a great deal on a hand held. The cheapest I have found so far is $450. I need one but not for $450
Jump on that quick.
Is it the right one?
I did buy it.
Unknown cable.
If your lucky it will have both an 8 pin for T! and a 12 pin for T2
FSIP will sell you cables
Yes that’s the right One. It may have the correct cable for your controller. You either have a T-1 (8 pin) or T-2 (12 pin) that programmer is gonna come with either one or the other. Like Rodney said what ever one you need you can buy from Flight System.
After you program your car I’ll buy it for
You for $200
Would like to see a pic of the mods to the rear that were made to do the lift and the seat add.
I’ll try to get you some pictures.
Meanwhile, here is the handset.
14 pin cable.
I might have to send it to one of you guys for testing.
Don’t want to waste money on cables if it’s no good or the wrong one.
I’m looking for cable pin-out diagrams, so I can make my own.
If I can’t find the information, would you be willing to take pictures and ring out pin to pin connections for me.
Here is link to 8pin genII cable.
New General Electric LX Handset Cable Gen II 8 Pin | eBay
Looks same as what I have???
Hard to see rear mods.
I just held camera under the side.
Hmmm
So much for the flex beam.
Does this puppy ride a little bit stiff?
Thanks for posting the pictures.
Don’t know what to compare it to. Seems ok.
