Hi to All!
I have a 1999 Gem and have a couple issues. I noticed my lights, wipers, directionals and basically all options were not working. When I took it apart to look into it, it then wouldn’t do anything. I noticed if I removed the Black wire on the Solid State Timer/Relay I get all my options back but still no Click noise and no power. I jumped the white and gray wire from CIT Relay and it clicks and goes! So…what do you think my issue could be?
Thanks in advance!
Mike
The charger interlock circuit maybe?
Thanks for the reply. Where would I find that?
I believe the 12v circuit runs through the charger. When connected to a.c., the charger opens the circuit, inhibiting operation, by removing 12v.
