Thanks for your insights.
Kim Hayes
20055 N 11875 E
Mount Pleasant, UT 84647
801-599-5519
Kim Hayes
20055 N 11875 E
801-599-5519
Greetings,
Thought I’d give you an update after extensive testing that included verifying the voltage on the individual battery cells and the output of the BMS. It was determined the BMS was junk. Manufacturer is sending me a replacement so I can install it and put things back together. By the way, all the batteries tested exactly the same voltage.
Best regards,
Kim Hayes
20055 N 11875 E
801-599-5519
