Hello! I want to do a fluid change on my 01 Gem. All I see is a rubber grommet/plug on the driver side of the diff. Is that where I pump the fluid from? Any info/direction will be much appreciated.
Yep. You will probably have to use a slurp gun, pump, fluid syringe, wet & dry vac or something similar to suck the old oil out. You can remove the diff cover and drain, but that’s a pain in the ass as IIRC, the cover hold down bolts are also the support bracket bolts, so you have to get the front end up and support everything. .
Takes about 16oz of oil. OEM spec is SAE30, which was done to eek out a bit more range from the battery pack. If you would prefer not to have to listen to the gear clatter, then use 75W gear oil.
PM me your email address and I’ll send you the shop manual and parts book.
