Where can I get tires for my 2002 Gem size 165 R 70 R12 77
Discount tire, Big 0 Tires, TireRack, Sams Club, Tires Plus…
Would you like me to keep going?
Mike KC, thanks for the suggestions. My problem is the size of the rim at 12 inches. I keep getting that they no longer make that size. I will try all the names you suggested and let you know how I made out. Thanks again.
Do you have any cart shops that in your area that may specialize in the special size?
Otherwise take a quick look on Amazon.
Ok, a couple searches later and you are correct - it’s been a long time since I have looked for stock tires - 12" tires seem to be scarce right now.
Looks like these guys might have some.
You can also use 155/80 R12 tires. That’s what I ran on my '02, they are like 3/4" taller. They are easier to find and might cost less. Seems Wal-Mart has them in the low $50’s / tire range.
I will give it a shot. Thanks.
I found a bunch of them on EBay, 40-$50.00
How well do they burn?
| jrjava
February 1 |
They seem to work well so far…
