Has anyone had any luck finding a source for replacement shock bushings on the older models? Mine is a 2002 e825, but IIRC, 1999-2005 are all the same.
I don’t really want to press the old one out until I have replacements, but roughly measurements are 1.181" OD, 0.72" ID, 0.82 LOA.
Results from online parts searches are mediocre at best because the dimensions aren’t always listed or indexed. I’ll talk to the local auto parts store and probably give Summit Racing a call, hopefully get a hold of someone who works in that department, but hoping someone else might have found something already.
Looks like Old_Houseboater sold out a long time ago (post from 2017) and I’d rather not go with the duct tape solution.
Yeah, it’s dual sleeved - outer and inner. I suspect that tubing would be too soft / compressible though.
I seem to recall reading that the shocks are custom made by Monroe for the GEMs, so there really are no aftermarket parts. The shock bushings are however very close in design to the chassis suspension bushings from a polaris bronco - there might even be a direct matchup, or at least a sledgehammer & grinder fit, but with no dimensions listed by polaris, just years and models, it might take a trip to a well stocked dealer.
I’ll dig up my notes on possible part numbers later.
