Regenerative braking doesn't work
I have a problem with my GEM elxd of 2011, I have no regenerative braking.
I try to put function 19 and 20 to 128 and I have a connection between the pin 12 of the controller and -72V but nothing
Regen is a complex relationship between several function settings.
In addition to 19 and 20, you might want to give 9 and 10 some tweaks.
Is your connection to p12 a permanent fix? Or momentary like a push button?
Do you have any speed modifiers attached to your speed sensor? (is your speed display accurate?). These will also affect how regen responds.
it’s a switch so when it’s active, it’s permanent
I have the OEM system of the speed sensor and I have no problems with the speed display
I try to change the functions 9 and 10 but there are already at the maximum
