This is a Quick Charge Multi bank charger. This charger has 6 Banks or Outputs, Each bank put’s out 12 volt’s at a max of 10 Amp’s. This is the ULTIMATE way to charge a Multi bank system like in a gem or Think. This battery charger take’s care or charges each battery individually. It’s not like a stock Battery charger that Bulk charges all 6 battery’s at once. This is the best way to maintain your multi bank system because it can bring back a week or lagging battery with out overcharging the rest of your battery’s. Also it gives you the ability to spot week or bad battery’s in you system.
Think of this Charger as one large Battery charger that holds 6 Individual adjustable battery chargers inside.
When you open up the charger you will notice 6 Individual battery chargers, Each one of them can be adjusted to charge a different battery chemistry.
I had this in my GEM when it had 6 Gell battery’s but you can adjust all 6 charger’s to charge Lithium or Flooded Lead Acid or Gell.
It has a Remote LED display that shows you the charge status of each battery as its being charged. I switched to lithium and the amount of lithium cells I went with This charger could not or wound not work with my configuration
It can mount behind the fire wall of the dash.
It has a factory Gem Interlock installed Plug and Play
It has a Remote LED charge display so you can see the status of the battery as they charge
Here is what it looked like when it was in my car and how I had it installed
This is the Remote charge display
This is what it looks like in your dash
