Hey guys… New GEM owner here ('22 E6). I’ve enjoyed reading the posts on batteries and performance upgrades. I don’t need anything crazy, but looking for more acceleration/top end speed. Added range is great, but not a necessity.
It seems like upgrading to lithium is the way to go. If I could get 35mph and faster acceleration, that would be great.
@LithiumGods I’m in FL and saw some of your info. Interested in pricing.
Not posted here - my thread got so off track I dropped it.
But yes, a controller replacement would get you much more acceleration, torque and a top end of 35mph.
I think a stock battery setup would work fine, I installed 60v lithium and I am literally spinning the tires when I take off from a dead stop.
Repro will give you 35 mph and everything else oem
Still working to crack the Torque
Everything else will work as oem
If you want more torque you’ll need to swap the controller like Dave and mike suggested
Thanks. Is this something you could do one at a time? Meaning… do the controller first to get the acceleration and torque - and then do upgraded battery if/when I wanted more range?
Yes, and the reason I asked MikeKc about any testing with lead.
So you would know what to expect.
We would need to partner on this one. I build the kit, but do not have a new gem here to test.
Mike needs to come up with a good running file.
Being an early adapter, we may need to do some fine tuning.
Be aware that this is reversable. Reinstalling oem controller will take you back to stock.
There are 2 parts to this. First is to increase speed. Next to increase power, we can program in more power but with lead batteries the results are minor. As soon as you add lithium the gem can get the power it néeds, there is a noticable gain
To do the speed and power upgrade on your equipment is about 1500. Or you can swap out controllers from Inwo for even more power and performance, about 2k
