How To Fix -90 error code
Sometimes you just have to think outside the box. This harness looks to be routed in an odd way, but I’ll get it straightened out.
When I bought this last month, all 4 wheels cylinders leaked and ate the shoes, 3 of the batteries were overfilled, 3 under-filled, and it had some serious fiberglass cracks in the body. I stripped the whole cart down to the frame, only to find the leaking battery acid through the rear harness. I cleaned up the frame, undercoated it completely, bought new brake kit from NEV, and started reconstructing the rear harness. I painted the body, front panel, and sides black, and left the top white. Once the rear panel is fixed I’ll paint that black. I’m looking to buy 2 new front seats and recover the back. All in, I should have less than $2,400.00 invested including the $1,500 purchase.
I have connectors, but just order “ampseal” 23p connecto. Must be same color. They are keyed.
You can order them from China with pig tails. Or, I have an auto feed crimper for amseal pins.
Uploading: 17069253712548559728589507791406.jpg…
Uploading: 17069254945058707782939834823741.jpg…
I need to get me one of these!
I had a -90 code after an update to the ECU. I guess it was updated from a T1 to a T2 then the -90 code popped up. Turns out the motor temperature sensor was the problem. I unplugged the two wires grey wire and terminal 21 and plugged them together and issue resolved. Runs 33mph now.
Nice job @ncdotmike.
This illustrates the value of the archives. If you have a problem, most likely someone else has also had the same problem. A well documented thread with a proper clear solution is worth gold in most common cases.
Good morning,
I wanted to jump in here to ask the best solution to this issue. I too have the - 90 code after a recent T1 to T2 swap. There are multiple suggestions in here. What is the easiest way to correct this issue?
I am not familiar with that error code, but you need this jumper in any case. IMO
I was able to find an old harness in my pile of GEM parts and depin an extra pin for spot number 21. Once I jumped pin 2 to 21, the -91 code went away and it’s running like normal again.
Thank you for the helpful thread!
