has any one seen this code I get it when I press the accelerator peddle and it goes away when I let off peddle. car seems to run fine
Code 90: terminal one is shorted to ground, input sensor error inspect motor controller
Incidentally all the GEM codes were posted by Daniel as “List of all GEM error codes” and are located in the “sticky” category under “Neighborhood vehicles” a couple of levels up in this blog.
Al
thanks al I will check it out now
