Hood & Spat delaminating
Believe me when I say I know what you’re going through! It’s the only reason I broke down and paid someone to do the job. When I was a few years younger, I would have stuck it out and did it myself. This is the part of getting old I could do without! I have the knowledge and the skill but lack the physical ability to do the things I use to take for granite. :rolleyes:
But being young like I am with kids at home I have no choice but to save when I can and try to keep this money pit somewhere near the budget.
I feel your pain I had a hood that had the same problem. I found that try to remove as much as you can via scraping it off. The stuff that remains I used a Heat gun on very low temp. If you get it too hot it will reattach and become even harder to remove
So you want to get it warm enough so that it doesn’t flake off but peels. And what remains must be sanded off. I did experiment with a plastic bumper stripper material that you spray on. You let it sit for a bit and try and guesstimate
When it has eaten through the clear and then remove it before it starts eating into the plastic. Unfortunately it leaves the plastic somewhat rough and it needs to be sanded.
Option number two is just forgo the stripper and use sand paper to remove loose clear
I didn’t even think about the heat gun. Too late now though, finished sanding and shot primer on it yesterday. Hoping for weather and time tomorrow for top coat. I found that the small scoff pad wheels for a Drexel gets into the hard to reach spots pretty good.
Sounds like you’re coming along nicely, be sure and take photos and let us see how nice it turns out.
Here it is, finally finished. Rustoleum Key lime green wet sanded 2000 grit then polished to a shine. Custom 6" lift with 2" forward extension. Rebuilt controller and charger, 130ah batteries, fusion stereo, polk speakers, tough coat bed and floor pan, r4f doors, 23×10.5×12 tires, rear bench seat for three passengers, multi function/color underlighting, 2 rod holders in rear of bed for marine gas grill and cutting board, new brake lines, new rear lights, and seat covers.
Forgot pic
That looks awesome great job. What are u going to be using it for?
Looks like some sort of pro mo or company vehical. Very nice
My wife is commuting to work with it, 2 miles round trip. Thank you for the props.
My hood is doing the same thing anyone have any idea how to get this stuff off?
Read this thread from the beginning
I read it before I asked the question. I do not read anything that delivers results. Have any of you successfully removed this stuff?
After only nine years of living in the Oklahoma sun, gel coat delamination just bit me overnight. Fine yesterday, but today I can literally lift the gel coat from the trailing edge of the cowl and the leading edge of the fenders are also bubbling.
I see that new pieces are available for about $900 unpainted but that isn’t my first choice. Any new fixes for this in the last four years?
As much as It may hurt to pay $1000 for a new hood and fenders from NEV accessories , You may be money ahead. Depending on how delaminated The hood is and war if you have any bodywork or cracks you might end up with a better product just buying a new hood.
I am not aware of any new techniques other than sanding the clear coat off with a DA sander and some 80 grit. Man that stuff sucks. ( The factory clearcoat ) thick as hell and A pain in the ass to get off
