Ok, then leave the controller floating(not mounted), and remove the F1 and F2 wires off the top of the controller. (These are easy. They just pull off)
If still present,
Then go for the A1 then the A2. Carefully isolate the cables so they dont spring off in a direction and ground out when testing.
That instruction was for the 2 wire motor temp sensor. It has a plug down on the end of motor. (not to be confused with the Speed sensor which has the 3 wire plug.
Was this not correct?
Today I was talking about the F1 and F2 wires. they have their own wires/plugs directly on top of the motor controller.
Interesting. Faint clicking?
Are any of your wires touching things they should not be?
Now that your Motor wires are disconnected from controller we can see if any of them are shorting to chassis.
Power off at MainSwitch (don’t need it).
Switch your meter to Ohms.
Place one meter probe on a clean spot on Chassis.
Place the other meter probe on the cable formerly connected to A1.
Do you get a reading? or OL on your meter?
Do same for A2
Do same for F1
Do same for F2
