Does anyone know how to remove the master cylinder on the Think? I’m curious if the plastic connections that run to the reservoir just pop off? I don’t want to put too much pressure in risk of breaking something. My cylinder is locked up and doesn’t allow the brake pedal to push past 1”. There’s no brake fluid which I assume is part of the reason it’s seized.
