Hi, I’m working on building an slow moving high torque EV that has 24V BLDC motors on each wheel but I can’t seem to find any that come close to what I need. I’m hoping with everyones experience you might be able to help me out.
Here are the specs:
350lb load on each wheel
24V
Torque = At least 65Nm
Power = .25HP or 180 watts
Speed = 1ft per sec
Tire - 10" diameter but that could change if need be. Golf cart size
This could be a pancake motor or, even better, a hub motor. All of the wheels would be direct drive and use a mono shaft.
If you could help me out I would be very happy
Thanks,
Dan
Check Australasian distributors for Advanced EV DC Motor
[QUOTE=danthedesigner;12305]Hi, I’m working on building an slow moving high torque EV that has 24V BLDC motors on each wheel but I can’t seem to find any that come close to what I need. I’m hoping with everyones experience you might be able to help me out.
Here are the specs:
24V
Speed = 1ft per sec
Thanks,
Dan[/QUOTE]
