Several things going on here:
First, It might be important to list which lithium pack you have installed. (Sure, I suppose I can look back at your history and possibly find it, But I am lazy).
95% down to 50% after sitting unused for a month.
That is odd. I don’t think I have seen a Square Display SOC drop while in storage. Usually it has to be powered up for it to count its beans.
When did you observe this drop"
- At KeyON? It will show full bars during a boot/display test, then drop to actual when done.
- Full when leaving driveway, but after two stop signs it dropped to one bar.
There seems to be an occasional peek at PackV and bars can be taken away if the SOC sees a huge V drop while driving. Maybe it saw this and did a peek at KeyON and self adjusted. There is still much that is unknown how the SOC does it’s calculations.
We might want to look at how you are putting your car into sleep mode. If you leave the Master Battery Disconnect ON then your DC Converter is still active and consuming power(even tho your Key is OFF).
Best practice is to shut that off unless you are charging. When done charging, shut it off afterwards. If you are going away for a while, Shut off the output FETs via the APP. Shut off all 3. CHG, DIS, and BAL.
I got stuck in limp mode when the original meter showed very very low and the actual BMS on the battery still had lots left (45%).
Also odd. I was not aware the SOC did this on the 2012 cars. (2016+ yes).
Were there any other active lights on your display? The only two I know of that would force a limp home are the Turtle and the Temp.
You said your APP was reporting SOC @45%. Did you happen to note the Voltages? How low was it? (especially under load?)
It might be a good idea to clamp a voltmeter directly on your controller (so you can see it while driving) then comparing it to what you see on your app. You will be looking for a radical difference in Pack V (between controller and pack). There are a handful of connections between the front and back that (if loose) can cause a drop when under load.
What motor is in this car? When was the last time it was serviced? Perhaps it is borderline time for a look
It appears that there is an ‘expectation’ of a parasitic drain on the battery by the Original BMS on the GEM,
There was no BMS on the Gen2 cars. The batteries were more/less left to their own. When they changed the body style in 2016, is when they added all the fancy (BMC, VMC, Dash) boxes showed up and started talking to each other.
