During a motor re-install into a gearbox mod a wire got pulled too much. Popped out the two wires from the waterproof connector. I need to know which wire goes where to re-build this connector. Easy but only two choices. Only two wires, but it changes color at the connector.
this connector goes to the controller.
Brown and black/white stripe.
This is the pulled out wires coming from the motor to the connector. Green and Red that go back to the motor.
Which wires go to which? Red to brown or Red to black/white stripe?
