I learned that there is more than one color of a multimeter, thank you everyone…
The battery voltage at battery pack is 76.3V and that is the same when I test the battery positive and negative up at the dash.
Apologize if this sounds remedial, but where exactly am I supposed to put the positive and negative from the multimeter elsewhere with the dash removed? I don’t want to mess anything up more so…
Dead center of the dash is the fuse panel. This block is called the PSDM and is the nerve center of the car where all 6 of the various harnesses plug in for distribution to other points in the car.
On the front of the unit are some big orange cables attached to studs.
The one on the left (driver side) is B+ (marked as +72v)
There are two on the right (pass side) and are basically the same
In most cases either one can be used for testing as a reference to B-.
Attach your meter to these points, take a reading with Main Batt Switch ON, then again with KeyON. What do you see?
No clicking, but the display doesn’t turn on with key on. The display illuminates for a split second and then goes dark. (Wiper was on initially and slightly moved as well when display lit up) Nothing works. Anything next to check?
So, when I turn the ignition switch on, the digital display illuminates for a flash moment and then goes back to dark. Nothing works—the car doesn’t engage, nothing works. While I have the dash off, is there anything else to check or a part, fuse, piece, wire that may be the cause?
Set your meter to read 12vdc (most likely a 20v scale)
Main Bat Switch ON
Black meter probe on the Chass Gnd (dash frame is OK)
Red meter probe on PSDM terminal S6 (see pic)
(there will be a Red/W wire on this terminal connection OK to pull it off for this test.)
Okay, so I think the clicking is still there. It doesn’t immediately click, but it does when key is ON about every 3 seconds—sounds like coming from somewhere in this area I’m doing the probe test.
I have this Fluke 115 multimeter that has a DC mode and it’s supposedly supposed to automatically switch to 12V but it doesn’t seem to be. When I’m on that 6th terminal it reads about 62V and then when it clicks it jumps up to like 70V
It is also exactly what I wanted to see when Key goes on. For now, leave key off.
Now, What do you have in the junk drawer that can run a bit of a load. Looking for something like an old 50w off road light. Maybe a replacement bulb? How about a trailer light bulb?
Just a bulb if you don’t mind holding on to it for a couple/10 seconds.
If all you have is a tail light, it would be a first test. a headlight, or fog light is is better. (like a H1 halogen).
Your converter is producing 12vdc. It can be seen on P6.
We also see that 12v takes a dive when Key is switched on.
The Surepower DC Converter has built-in short circuit protection if over current occurs.
I am trying to determine if there is a short somewhere in the Keyed ON system that is not protected by one of the fuses or the regulator in the DC Converter has failed and not able to produce even the slightest amount of current needed to switch on the keyed accessory systems.
By testing the constant ON (without switching the key) it gives me a bit more info on where the fault might be.
Hi,
Idk if it’s because I don’t have a trailer light, but I have a turn signal that has a ground wire and a power wire, when I press the ends of the wires against the S6 tab and the chassis ground nothing happens. It doesn’t light up. But when I check the S6 tab and chassis ground with my volt meter, it has power.
