Purchased may 5th 2020, installed may 13th 2020.
Thank you David and Mike!
Put in full service that day. Daily average 35 miles at 35 to 45 mph. Charging at home for lunch and a tiny bit at work. Using a heavily abused 88volt 6kwh ford c-max battery pack built from (4) 21 cell packs of 24ah cells. Because I hot foot it around with lots of hills and stops, my pack milage is still 20 miles but that’s going 45mph a lot. When I go slower, the pack can last 23 miles easy. Way better then the stock set up at 18 miles or less and a smoking hot melting stock motor that would only do 38 in the flat. I now go 45 up hills or down. Stays 5000rpm no matter what unless your voltage drops a bunch.
The induction motor is smooth on takeoff and pulls like a freight train above 10mph and keeps pulling til 45mph or just higher.
Interested in trying other tunes but I’m so happy with my setup it’'s not an issue. Love my truck!
Approximate mileage used so far in about 50 days. 1500 miles, probably a low estimate.
Drive through downpours, mud and sand. The motor is constantly full throttle gets warm but never hot. Yes I am running it hard but no hiccups ever.
