Looking for some advice on the right setup for climbing long, steep hills with my 2000 4 seater.
Here’s the scoop - For me to get out of my little pocket of San Diego and go any real distance, I have to go up and over a pretty large hill (Del Cerro hill for anyone local). The longest stretch I have is about 1.5 miles and ascending 500 feet, believe it’s 15%+ grade at certain points. Unfortunately, that climb is usually on the return trip so if I run around too much before hitting the hill, I could get stuck. When I get to the top of the hill, everything is hot and you can tell the car is straining… summer I got an overheat code on the T1 controller (have a new t2 in the garage I just haven’t gotten around to putting in).
I’ve been curious to check the voltage at the bottom to the top. I think last time I did it I was at 70% going into it and ended up at 35-40% at the top. (fortunately for me, if i make it to the top, it’s all downhill to my house from there)
My setup -
- 2000 GEM 4 seater
- Ride 4 Fun Motor
- Ride 4 Fun 14" wheel package
- 6 wet cell marine batteries (6 months old) - yeah, yeah… i get it… not ideal batteries. I just needed to get the thing going when I bought the car as it had a mis-match of group 27 batteries (i knew that going in and negotiated that out of the purchase price)
- T1 controller, which will probably get swapped out to a new T2 when the wife is black friday shopping
- 10.xx:1 ratio gearbox
Potential options
Re-gear the gearbox - I think what I need to do is re-gear the gearbox to 12.44. I’ve read just about every post on gearboxes on the forum and the answer seems to be, call Marlon… I shot him and email and gave a call/text but haven’t heard back (mind you, that was this week and it’s a holiday week so not terribly surprised… and marlon would be awesome since he’s out of the SD area).
Do you guys think this is the right move? What do you think I’ll lose in terms of speed? Part of the reason I put in the r4f motor was so I wouldn’t get run over on 35 mph roads and to climb the hill; I don’t need to do 40+ but would like to do at least 30-35 on the flats. Any idea where I can source parts? (Rodney?) . Found a couple of complete gearboxes on Ebay but the seller wasn’t sure how they were geared.
I’ve been obsessively readying the forum about the Lithium conversions… figure shedding weight couldn’t hurt. I’ve learned a heck of a lot through the forum; head was spinning like crazy in the beginning but I’m piecing it together. The tricky part is folks are learning VERY quickly so what someone did in '16 and posted about, they probably won’t do today. Don’t be surprised if you see yet another lithium dummies post from this guy.
Question here would be even if I did Lithium, would I still want to change the gear-ratio anyway? If so, I might as well start with the gear option first and see how I’m doing. Also, there was a lot of suspension discussion for the earlier GEMs… is that still valid? Will it run like crap if I shed all that weight? I’m going to stuff myself will turkey but that definitely won’t make up the 400lbs
Side but related note - I have another thread going about flipping a cheap 4 seater I picked up. casually threw out the idea of keeping it for a lithium experiment and daggers flew out of my wife’s eyes!!! so that’s out.
Is there anything else I should be considering?
- Guess I could go back to the stock 12" tires but those look lame. Not that I need it looking fully customized and “pimped” out, just a little better
- is there a bigger motor I could try? figure that will get me up the hill faster but won’t help with amp draw and capacity
Appreciate the advice!
-Ernie
