[SIZE=2]Image courtesy of BMW
Consumption[/SIZE]
[ul]
[li]CO2 emissions in g/km: 49[/li][li]Consumption combined in l/100 km: 2.1[/li][/ul]
Range and charging duration
[ul]
[li]Electric range in km: 37[/li][li]Electric range (mean customer value) in km: 25-35[/li][li]Maximum total range in km: 600[/li][li]Capacity of lithium-ion battery in kWh: 7.1[/li][li]Charging time of high-voltage battery in h at 3.7 kW/12 A (80 %): 2.5 hours[/li][li]Charging time of high-voltage battery in h at 16 A (Wallbox) (80%): 2 hours[/li][/ul]
Weight
[ul]
[li]Unladen weight in kg (DIN): 1,485[/li][li]Permitted total weight in kg: 1,855[/li][li]Vehicle load capacity in kg: 370[/li][li]Permitted front/rear axle load in kg: 895/995[/li][/ul]
Performance
[ul]
[li]Maximum speed on purely electric power in km/h: 120[/li][li]Maximum speed in km/h: 250[/li][li]Acceleration from 0–60 km/h on purely electric power in seconds: 4.5[/li][li]Acceleration from 0–100 km/h in seconds: 4.4[/li][li]Elasticity from 80–120 km/h in seconds (4th gear): 3.4[/li][li]Elasticity from 80–120 km/h in seconds (5th gear): 4.0[/li][/ul]
Wheels
[ul]
[li]Tyre dimensions front (standard equipment): 195/50 R20 93W XL[/li][li]Tyre dimensions rear (standard equipment): 215/45 R20 95W XL[/li][li]Tyre dimensions front (special equipment): 215/45 R20 95W XL[/li][li]Tyre dimensions rear (special equipment): 245/40 R20 99W XL[/li][li]Wheel dimensions front (standard equipment): 7Jx20 H2 IS36[/li][li]Wheel dimensions rear (standard equipment): 7.5Jx20 H2 IS40[/li][li]Wheel dimensions front (special equipment): 7.5Jx20 H2 IS40[/li][li]Wheel dimensions rear (special equipment): 8.5Jx20 H2 IS50[/li][/ul]
Online reviews:
[SIZE=2]
“The i8 represents a brave, groundbreaking move by BMW to bring sports cars into the modern age. It looks and feels like nothing else in this class, and manages to be every bit as exciting to drive as it is to stare at”…What Car
[/SIZE]
