Is there a label on the motor (of a 2007) that indicates if it is a 5hp or 7hp motor?
Yes most motors have a label that says GE 5HP or GE 7HP
Thanks for the info!`
Did you figure out what motor you had?
I can’t be sure of this info, but most cars I have come across that have a 7hp they have a cool air kit installed. It’s the plastic air scoops the re direct air to the motor and a heat sink on the controller with a fan. If your car has these things also then you have a real good chance your car has a 7hp
