Don’t know if anyone has ever been to www.batteryhookup.com, but I wanted to ask if anyone has any feedback they could give on using this battery from old BMW Stock, 14S 8kwh battery.
Before you spec batteries you need to know what your chargers finished voltage is . Example: a 72v DeltaQ charger on Gel will do a finish , balance voltage at 96v . You hook up a 72v lithium battery to that and you could have a real problem . Test your finish voltage . Then you can determine the number of cells required .
