# Volt Lithium install for Dummies. 00' e825
**URL:** <https://community.electricforum.com/t/volt-lithium-install-for-dummies-00-e825/13145>\
**Tags:** lithium\
**Created:** [December 17, 2017, 5:59pm UTC](https://community.electricforum.com/t/volt-lithium-install-for-dummies-00-e825/13145 "2017-12-17T17:59:54Z")\
**Showing post:** 5
**Author:** ![ryan380golf](https://avatars.discourse-cdn.com/v4/letter/r/4bbf92/32.png) [@ryan380golf](https://community.electricforum.com/u/ryan380golf)\
**Post date:** [December 17, 2017, 8:26pm UTC](https://community.electricforum.com/t/volt-lithium-install-for-dummies-00-e825/13145/5 "2017-12-17T20:26:26Z")
![20171214_102802](https://canada1.discourse-cdn.com/flex030/uploads/electricforum/original/2X/a/ac0d1cbbc579117b7c065273153839cff4f2d535.jpg)
Lay battery on it’s end. This was a failed start with my plunge saw. Too slow. Grab a Sawzall with a long blade. Slice it straight down taking off all of the tabs. You will reduce the width to just under 7 inches. The same width of a car battery. Now you can place them in your stock battery trays. The rubber gaskets will smoke a little as your cut through them.
 ![20171214_131700](https://canada1.discourse-cdn.com/flex030/uploads/electricforum/original/2X/c/c84ad64747938b905fea0a6fc2d9ba2590c82cef.jpg)
 ![20171214_131716](https://canada1.discourse-cdn.com/flex030/uploads/electricforum/original/2X/c/c7f3dd1d15a20b1e0f396b66279ffc8c8afd3462.jpg)
_[View the full topic](https://community.electricforum.com/t/volt-lithium-install-for-dummies-00-e825/13145)._
