Hmmm Fully charged battery pack is 76 volts. You may have a dud even they are new, Not fully charging is an indication of that. Do a brake load test. hook your meter to 1 battery. Hold the brake and bury the throttle for 2 seconds. Repeat on the rest. The dud will show up. Let us know how you make out.
