# Real noisy after gear change
**URL:** <https://community.electricforum.com/t/real-noisy-after-gear-change/28623>\
**Created:** [November 30, 2024, 5:03pm UTC](https://community.electricforum.com/t/real-noisy-after-gear-change/28623 "2024-11-30T17:03:15Z")\
**Showing post:** 27
**Author:** ![JarJarJava](https://yyz2.discourse-cdn.com/flex030/user_avatar/community.electricforum.com/jarjarjava/32/15158_2.png) [@JarJarJava](https://community.electricforum.com/u/JarJarJava)\
**Post date:** [December 2, 2024, 7:06pm UTC](https://community.electricforum.com/t/real-noisy-after-gear-change/28623/27 "2024-12-02T19:06:56Z")
I asked about the imput shaft because i had similar situation. Replaced an input bumper and it was the bearing and the shaft being worn out
> [@Changed motor-diff resilient bumper, motor now growls and spedo is out. WTF](https://community.electricforum.com/t/changed-motor-diff-resilient-bumper-motor-now-growls-and-spedo-is-out-wtf/16251):
> 02 longback stock 5hp GE 10.35 trans Changed the resilient bumper out, took the car out for a test drive, barking on decel is gone, but there is a growl almost like gear teeth chattering at speeds and the speedo barely registers any speed. Took the motor off, stood it on the back end to use a pick to pull out the old bumper, put the new one in, greased the splines, reinstalled. Got the grinding at full speed. Came back home, motor seemed overly hot for a 3 block test drive, pulled it all ba…
_[View the full topic](https://community.electricforum.com/t/real-noisy-after-gear-change/28623)._
