# LCD broken or needs resetting?
**URL:** <https://community.electricforum.com/t/lcd-broken-or-needs-resetting/16899>\
**Created:** [August 22, 2019, 11:30pm UTC](https://community.electricforum.com/t/lcd-broken-or-needs-resetting/16899 "2019-08-22T23:30:54Z")\
**Showing post:** 4
**Author:** ![RS\_E6](https://yyz2.discourse-cdn.com/flex030/user_avatar/community.electricforum.com/rs_e6/32/12308_2.png) [@RS\_E6](https://community.electricforum.com/u/RS_E6)\
**Post date:** [September 7, 2019, 2:13am UTC](https://community.electricforum.com/t/lcd-broken-or-needs-resetting/16899/4 "2019-09-07T02:13:02Z")
> [@Battery display always indicates empty (one bar)](https://community.electricforum.com/t/battery-display-always-indicates-empty-one-bar/12799/2):
> Turn the key on. Push and release the TRIP/ODOMETER switch until it’s showing the odometer. While holding the switch down, turn the RIGHT signal on, then the LEFT signal, then return the blinker to the center. Release the TRIP/ODOMETER switch. You should be seeing data (P0105) on the display now. Turn the RIGHT signal on, then off repeatedly until the display reads: SOC (State Of Charge). Push and release the TRIP/ODOMETER switch. Now it’s remaining capacity in percent. You can now raise (or low…
_[View the full topic](https://community.electricforum.com/t/lcd-broken-or-needs-resetting/16899)._
