# Front mount battery in early Gem
**URL:** <https://community.electricforum.com/t/front-mount-battery-in-early-gem/23842>\
**Created:** [March 29, 2022, 3:31am UTC](https://community.electricforum.com/t/front-mount-battery-in-early-gem/23842 "2022-03-29T03:31:48Z")\
**Showing post:** 33
**Post date:** [March 30, 2022, 3:11pm UTC](https://community.electricforum.com/t/front-mount-battery-in-early-gem/23842/33 "2022-03-30T15:11:12Z")
I am mentally wrestling with how/best way to do wiring on this.
- Will the BMS fit in one of the cases and be OK? (heat buildup)
- Can the 11 of the balance leads be split off and have an easy disconnect plug going to the other battery?
- Is that going to drive the BMS balance calibration nuts?
- External lugs in the sides or top for suitcase interconnect? (disconnecting a main jumper without disconnecting a balance jumper might not be good for the BMS.)
_[View the full topic](https://community.electricforum.com/t/front-mount-battery-in-early-gem/23842)._
