# Covert to 8V gell battery
**URL:** <https://community.electricforum.com/t/covert-to-8v-gell-battery/11930>\
**Category:** Battery & Chargers\
**Created:** [January 12, 2017, 10:46pm UTC](https://community.electricforum.com/t/covert-to-8v-gell-battery/11930 "2017-01-12T22:46:02Z")\
**Showing post:** 4
**Author:** ![Inwo](https://yyz2.discourse-cdn.com/flex030/user_avatar/community.electricforum.com/inwo/32/1067_2.png) [@Inwo](https://community.electricforum.com/u/Inwo)\
**Post date:** [January 14, 2017, 2:58am UTC](https://community.electricforum.com/t/covert-to-8v-gell-battery/11930/4 "2017-01-14T02:58:26Z")
Voltage and number of cells is the same.
Charger profile will follow battery type not arrangement of cells.
Miles will follow AH ratings less diminishing returns for weight.
If you go from 100ah to 150ah. In theory 10 mile range would go to 15 miles.
In practice expect 1/2 that increase. IMHO
Rodney would know more. He’s been there done that.
Read the latest Lithium thread. See how easy a first time conversion to 20s Nissan Leaf pack was.
> [@Reprogrammed my T1 controller using my Windows 8.1 laptop with a USB dongle made by Inwo](https://community.electricforum.com/t/reprogrammed-my-t1-controller-using-my-windows-8-1-laptop-with-a-usb-dongle-made-by-inwo/11920/8):
> It was pretty easy to set it all up. I put the charger and battery in the same spots, and was able to utilize the existing cabling, etc. I had to run one wire from the charger to the BMS, drill a few holes, and bolt everything up. You can’t really tell from the pic, but the pack has an aluminum frame with places to put bolts. If fit the center of the battery bay perfectly, and the mount points were above aluminum plates welded to the frame. If I added two cells I don’t think it would fit in…
_[View the full topic](https://community.electricforum.com/t/covert-to-8v-gell-battery/11930)._
