# 2016 E4 High Voltage Conversion in SD
**URL:** <https://community.electricforum.com/t/2016-e4-high-voltage-conversion-in-sd/22098>\
**Created:** [August 9, 2021, 5:24am UTC](https://community.electricforum.com/t/2016-e4-high-voltage-conversion-in-sd/22098 "2021-08-09T05:24:51Z")\
**Showing post:** 35
**Author:** ![Erniea15](https://yyz2.discourse-cdn.com/flex030/user_avatar/community.electricforum.com/erniea15/32/10887_2.png) [@Erniea15](https://community.electricforum.com/u/Erniea15)\
**Post date:** [September 2, 2021, 5:09pm UTC](https://community.electricforum.com/t/2016-e4-high-voltage-conversion-in-sd/22098/35 "2021-09-02T17:09:26Z")
I ended up ordering the CAN translator so I can monitor the controller -
> **[Canbus Translator - Display](https://www.thunderstruck-ev.com/can-translator.html)**
> Use the Thunderstruck CAN Translator with a Bluetooth OBDII transmitter  not included and your own bluetooth enabled smartphone or tablet to show real time information from the system controllers used in many of our kits Using the downloadable Torque...
Any tricks or pointers to getting it hooked up other than this thread?
> [@8KW Motor - Sevcon Controller - Digital Dash](https://community.electricforum.com/t/8kw-motor-sevcon-controller-digital-dash/18438):
> Ok been working with the guys on the 8KW Conversion, now we have a viable dashboard. Here is a 16’ GEM E4 with: 8KW AC Motor Sevcon Gen4 Size 6 Controller ThunderStruck CanTranslator Bluetooth ODB2 transmitter Android Tablet Torque Pro (4.99) Cost for the Can Translator and Bluetooth Transmitter is 120.00 @Inwo@grantwest@LithiumGods@bundcur
Update since I originally posted - I just got an email from Thunderstruck - “Hello and thanks for ordering with us. There may be a small wait on your CAN Translator. It originally was designed for use only with our controllers that we sell, since we program the controller to work with it before shipping them out. However, we have a version that will not require programming that should be finished very soon. I’ll send you a tracking number as soon as it is ready.” @MikeKC does that make sense to you?
_[View the full topic](https://community.electricforum.com/t/2016-e4-high-voltage-conversion-in-sd/22098)._
