# 2005 gem EL wiring
**URL:** <https://community.electricforum.com/t/2005-gem-el-wiring/20164>\
**Category:** Uncategorized\
**Created:** [October 29, 2020, 8:21pm UTC](https://community.electricforum.com/t/2005-gem-el-wiring/20164 "2020-10-29T20:21:09Z")\
**Posts on this page:** 3\
**Page:** 1
<div class="post-metadata">
**Author:** ![Gembo](https://avatars.discourse-cdn.com/v4/letter/g/f9ae1b/32.png) [@Gembo](https://community.electricforum.com/u/Gembo)\
**Post date:** [October 29, 2020, 8:21pm UTC](https://community.electricforum.com/t/2005-gem-el-wiring/20164/1 "2020-10-29T20:21:09Z")
</div>
vehicle will drive with parking brake on. only has a green and white with green stripe wires at micro switch
**Author:** ![Gem\_e2](https://yyz2.discourse-cdn.com/flex030/user_avatar/community.electricforum.com/gem_e2/32/1849_2.png) [@Gem\_e2](https://community.electricforum.com/u/Gem_e2)\
**Post date:** [October 29, 2020, 9:13pm UTC](https://community.electricforum.com/t/2005-gem-el-wiring/20164/2 "2020-10-29T21:13:32Z")
</div>
Hi
yes 2005 and 2006 cars have that problem
from 2007 cars you can not drive
**Author:** ![Old\_Houseboater](https://yyz2.discourse-cdn.com/flex030/user_avatar/community.electricforum.com/old_houseboater/32/544_2.png) [@Old\_Houseboater](https://community.electricforum.com/u/Old_Houseboater)\
**Post date:** [November 11, 2020, 12:49am UTC](https://community.electricforum.com/t/2005-gem-el-wiring/20164/3 "2020-11-11T00:49:31Z")
</div>
See 2005 problem solved.
> [@2005 problem soluition](https://community.electricforum.com/t/2005-problem-soluition/20179):
> 2005 GEMS do not have a method to prevent cart operation with the parking brake engaged. By adding $25 worth of parts and a couple of hours work this problem is easily corrected. PARTS (2) Regular parking brake limit switches. Do NOT reuse original. 6 bucks each at Club Car Dealer. (10’) 16 ga. wire (6) Ty Wraps (2) 1/4’ female spade connectors (2) butt connectors (2) 3mm X 1 1/4 " machine screws with nuts (1) piece steel scrap for joiner Solder Normal hand tools plus Heavy d…
